Framebuffer - scroll bar hides the checkboxes
check the screenshot
C4D Studio R21.207 - Corona 5 HF 2
macOS 10.14.6 Mojave
Hi, Thanks for letting us know!
Update. Internal use: (Internal ID=467670340)
The error is still there and is getting really annoying.
mind sharing a bit more information about this issue? I just tested it with the latest daily on 10.15.6 Catalina with R23 and it doens’t seem to happen. (Attaching a picture)
Thanks,
Jan
I can confirm the error: OSX BigSur 11.2.3 / Cinema S24 / Corona Build 2021-04-16
Catalina 10.15.7 - Corona 5 -7 - This issue was also in older OSs
it depends on how you open the framebuffer. If you click directly on interacting rendering, there is the scrollbar problem. If you open the framebuffer directly first, then this does not happen.
I use the interactive rendering button 99% of the time.
Thanks for the repro steps, it really helped (I am more of a VFB->IR guy, that’s why I didn’t reproduce it.)
Adding to internal tracker (Internal ID=683950640).
In the meantime, what worked for me was re-running Interactive in the VFB after (long-press Render and select IR), it moved the checkboxes to their correct position and kept them there even after closing VFB and running it through the Corona Menu (not VFB).
Thanks,
Jan
