when zooming out to limit on framebuffer window and is crashing out 3dsmax.
Here too ! after installing the sp1 update for max 2014.
i will try max 2013.
Rendering my scene in max 2013 with the previous alpha 4 was fine !
Just after that i’ve replaced alpha 4 with alpha 5 and reloaded my scene, i hit render and i have this weird bug :
Framebuffer and max looks like crashed, i’ve even hit cancel and it doesn’t help only if i do it with in task manager !
Any explanation ?
Confirmed : I did test the framebuffer type and the default one in VFB settting works good without crashing things.
When i change to Custom WXwidgets it crashes and it stays on “Transforming Vertices” and i have to hit Escape to close it.
I hope it can be fixed.
Yes i know i can deal with it, but tell me about VFB+, because i have it installed and all i have in it is black, when i disable it and return to max default framebuffer the render is ok !
Ok it works good now with VFB+ after reinstall !
Not sure if it was fixed with the newest build. Anyways, there is a duplicate entry in mantis
