Freelancer needed for simple interior set
Hi all,
Sadly, as a solo freelancer I’m unable to accept all my clients work.
I’ve got a job on offer. It’s 4 apartments, (all basically the same furnishings/style, similar styling and layouts) each with 3 views (2 of which are variations showing a Murphy bed up/down). All the joinery, curtains, furniture, fixtures, wall colors, tiles etc are already specified so there is very little to do in terms of hunting for appropriate bits and pieces.
A PDF plan is supplied but no 3d, the interior spaces are simple (extruded walls with flat floor and ceiling). Camera Views are suggested but not concrete.
In total there should be approx 13 renders (so 3 of each apartment plus a bathroom render). The apartments are very small so although 13 sounds a bit daunting it should be fairly straightforward. My clent has written very clearly all the required info so you should be able to begin immediately.
Lighting/time of day is your choice. The renders should be probably 2560x1440 (maybe 4k but probably not).
Deadline is approx 2-3 weeks from today. Happy to supply more info if needed.
If you’re interested please PM me asap (hopefully with a very rough quote). Thanks!
Hello i m interested for this freelancing work.
I would like to know more also :smiley:
Thanks to those interested.
This job has been filled now. Apologies if I didn’t manage to get back to you personally.
