I have problem with DR with scene(file more then 10GB).After starting corona saves the file and that’s all, nothing happens.
I don`t have problem with this scene if i use render without DR.
DR works without problems with files less ~4 GB.
I don`t know how create debug files because 3ds freeze
3ds 2020
Corona Renderer 6
i9 and i7,ssd,32 GB,1Gb network
That’s very weird, I don’t think we’ve ever had a similar report. Would it be possible for you to optimize the scene somehow to make the file smaller? For example, you could turn some heavy objects into Corona Proxies, so they would be loaded and transferred as separate assets. I am not sure if this is even related, but a 10 GB Max scene sounds like an overkill (but maybe it is not?).
Just to make sure I understand this right: the freeze happens on the master machine? You start rendering, it saves the file, and then Max freezes?
The minidump is captured on the master machine during the freeze?
In the log, the Windows user name is C:\Users####\ because you censored it, or is it really the name? I think it could be causing problems.
Hello, could you send us any of the problematic scene? We would need it archived with all assets and uploaded either through our private uploader (Chaos) or through any method of your choice (e.g. Dropbox or Wetransfer). After the upload, please let me know what’s the file name. If the scene is confidential, please do not post the download link here, but send it to me through a private message or email. Thanks in advance!
I have upload test.max scene on dropbox
Unfortunately I cant provide my scene, but I created test scene. Its a simple scene with many elements.
Of course this scene may be optimized, but my scene can`t be or it will take a lot of time.
Hello, what is your RAM usage when opening and when rendering this scene? For me, ust opening it took almost 32 GB of my RAM (and you mentioned that you have 32 GB as well). If you are running out of RAM, you should also see the Corona’s “System is running low on RAM” error message.
If that’s the case, DR and many other things may stop working and that would be expected. The solution in such case would be either optimizing the scene to use less RAM, or installing more RAM in your PC.
Here are some tips on optimizing RAM usage - https://coronarenderer.freshdesk.com/support/solutions/articles/12000023310
Thanks! I will try to check it.
It is very strange because I have the same warning and error(61GB RAM needed) for 3 GB scene but DR works. But for 5 GB scene(61 GB Ram needed)but DR dose not work.
Hello, I have just created a support ticket 196509. You should get a message to your forum email address with more details. Let’s continue there, as it will be much more convenient for both of us.
Let me know here or by email if you can’t see the message or if you have any other questions.
We have the same thing here with Corona 6 hotfix 2 and max 2019. It does seem to be fully related to the size of the max file, since enabling or disabling compress on save can make all the difference.
The freeze is consistent, it always happens if the max file size is too big and distributed is used.
There is no freeze with the same file rendering without distributed.
A partial workaround is to enable compression on saved file.
3 GB works and 6 GB does not, which makes me feel that a 32 bit int is used to transfer the file size, limiting it to exactly 4 GB.
In the previous cases this was caused by running out of RAM and either optimizing the scene or installing more RAM resolved it.
Can you please make sure that RAM is not exceeded at any point of the rendering on both the render nodes and the master?
Please note that “exceeded” does not mean over 100% RAM usage, but rather something around 80-90% should be alarming because of the reasons listed here: https://forum.corona-renderer.com/RAM FAQ
