fregmented / flickering image
hi, I’ve got an issue with a file consisting of meshes + ifc import and visualarq blocks. Whilst I’m wll aware that Visualarq isn’t yet “fully supported” by Enscape, however the issue I’ve encountered is quite different then those I had or read about in forums. The image I’m getting from my model is very segmented, unclear and moving the camera creates flickering and stuttering without any apparent clarification of the image. The render and image qualities are set to the max nontheless this is the image im getting.
Whilst in another model exploding the visualarq blocks helped solving other issues, however here it did nothing, Also, exploding the IFC import will result in a massive amount of exploded mesh faces and also doesnt seem to solve the issue
Hi @contsla , allow me to copy a reply of mine which mainly applies here as well:
The ground plane of yours doesn’t look as large, but it may still be worth trying to reduce it to see if it makes a difference.
Hi @Demian_Gutberlet
Unfortunately having it moved to the origin point of the file didnt help. I also tried to reduce the meshes of the objects from an imported IFC. And that didnt help. I am however unaware of how to reduce the GroundPlane size. Googled it and it didnt show me any pertinent answer :frowning:
So just as an update. Did manage to solve the issue. Created a new file, copied everything and moved it all to the origin of the world plane. This seemed to solve the issue. In case someone encounters the same situation…
Thanks @Demian_Gutberlet
