fresnel reflections differ with AA methode
playing with flipsides studio setup, i noticed, that the fresnel reflections differ with AA methode.
what’s the reason behind? bug or feature?
-oconv
It’s not happening in my tests so I guess you’ve done something wrong with your material setup or the scene itsself.
If you decrease the Cut-off threshold for the reflective material, it will be fine in both modes.
well. figured it out. seems to be a bug.
it happens, when the threshold for adaptive subdivision is below 0.1
-oconv
It’s not exactly a bug, as I said, if you decrease the Cut-off threshold of the reflective matrial, it will go away.
Aren’t you two talking about two different thresholds? Vlado seems to be refering to the one in the raytracing options in the material, and oconv is talking about the threshold for adaptive AA.
indeed. so many parameters :slight_smile:
increasing the fresnel ior, or lowering the refraction ior makes it also disappear. (aa threshold still on 0.05 and cutoff still on 0.01)
is there any insight, how the two ior values are tight together in case of fresnel reflections?
what are the two values for “real world” materials like plastic, chrome etc.?
-oconv
