From A5 to new daily -> problem with DISPLACEMENT map
Hi Ondra,
when I open an old scene with map in the Displacement map, now, the same displacement map position ,is in the “Reflect BG ovveride”.
SO, for this maps, I have to change the position manually.
Also, the value conversion from official A5 to Daily is wrong.
And value 100 is too much. Usually, in arch-viz we work in cm and 100cm with displacement is very high! Better 1 as default in my opinion.
fixed
Same problem for the Self illumination maps. They disappear in the new A6. But in A5 was correct as a position in the shader.
