its without denoiser in both case
the only thing that help vray to get more clean image in minutes is Portal lights
in corona portal light not effected
Maybe Probabilistic Lights is turned on? Try turning it off, sometimes this leads to more noise. I use it only when there are lots and lots of light sources.
of course not. it doses the denoising process after stopping the render. But it has an option for just remove firefly which is not relevant here.
but vray has the option to determine the progressive updating frequency which corona does not and give an edge here to vray. You can decide when to stop render in a more proper way with vray.
