Trying to use Frost to complement a cascade solution. The first simulation is fine, but I cannot find a way to connect the second, cascaded simulation. Also hope there is a way to use Frost on the Foam. Frost complains that no position is given for the Foam. Is there a way to connect Frost with the Foam even though it is not a particle? How does Frost read Phoenix when it is not particle based?
Phoenix Foam and Splash are particle systems, perhaps Frost can’t read them, we have to try this.
If the different elements of Phoenix allowed prt export this would enhance post sculpting of the flows.
