frosted glass and render time
hello all
please can you help me to find a trick that can tell vray speed with frosted glass in the scene
when i put this frosted glass in the scene the render time and the noise is going crazy… like 3 hours for HD and with aa 1 to 100 with noise threshold of 0.005… its not good
if i hide this frosted glass the render time go down to 1 hour with much more clear image
i tried to disable shadow of the frosted glass object and its not help
any help will be great !
the render:
I’m not sure that much can be done about this. 3 hours for HD render on one machine is not bad, if you are using brute force. 1/100 is a slower method too…Its a nice render btw.
One way to speed it up is switch to IR / LC, pre calculate and save the light maps with the glossiness in the glass set to 1 so it’s not frosted, then render from the saved light maps and turn the frosting back on.
ok
update
i deleted the other side of the milk glass and put plane light as a real light outside the windows and i cut the render to 1 hour
i also put min 1 and max 24 and 0.005 on noise treshold and yes its go 1 hour for 2 k and look ok
the problem is… all the element \ passes look noise free and good butt only the reflection pass is grainy :frowning:
im on the new vray with auto subdive …im not going to go back to past and start adjust all suabdive … but how i can tell the new vray to put more subdive to the reflaction area?
look at the passes
try excluding the glass panels from GI calculation
Try those settings:
- uncheck divide shading subdvs
- min shading rate =1
- Make all ur materials/light/gi 8 samples
- Adaptive amount set it to 1.0 (if ur using BF, if IM leave it default)
- use min max 1-5 and raise it up to 1-8 if u think is necessary (i think u dont need more for this image)
- use noise thresh 0.02 to 0.015 for starters and i think u ll get fine results. If u use denoiser even with 0.03 - 0.025 u can have a good image with much greater render times.
Cant explain all these in detail will take too long, is the way i sample :smile: just do a check and if u find this method working good for u (instead of the universal settings), i ll do my best to explain.
Happy new year!
hi Thanulee,
i ve tried your setup on a scene i have problems sampling usign universal method, but using your settings produces quite a lot of noise at above mentioned levels.
Unless youre using some magic button not mentioned :slight_smile:
Hmmm i use this method for everything without issues and without noise. Only thing that can cause u noise, is bf on this setup. If u can upload ur scene i ll give it a look, im curious if i forgot something.
i ve tried raising everything twice and it still does it…i ve got quite a lot of MB and DOF and glossies in the scene though so perhaps its not meant for such cases.
So my scene is still a noisy Loisy.
Cant post it unfortunatelly, got NDA on it, thanks for the offer though!
Oren,
Try increasing default value of “Retrace” in LightCache to 8-10. It looks like vray is straggling to clear all the reflections behind glass.Reduce your image samples (bucket mode) 1/40, 0.005, it should be ok?
Good luck
Zoran
No worries. Well if u got dof from camera, values around 1-24 are needed. For any other case 1-6 is enough, if heavy glasses in the scene 1-16. This with IM shouldnt have any noise at all. With bf, is one way increasing bf samples as well.
Idk if i described u something wrong but i never had any kind of noise whatsoever with this method and i know with precision how to target my samples. I never go beyond 0.01. Too bad i cant have the scene i am so curious to see why the noise hehe.
If u want more on this sampling method, go check this one http://www.rese-arch.org/bundle/v-ray-essentials
Cheers!
