Frosted glass option not working
Hello, i try the option frosted glass but she don’t work. do you have an idea ?
Hey, I’m sorry to hear about that. Could you tell me what host software you’re using? I assume SketchUp? What Enscape release do you use? You can look this up in the [About] window.
Also, could you post a comparison how glass looks for you when the frosted option is enabled vs. when it’s disabled?
Thank you in advance.
“Frosted glass” only blurs what you see through it; you have to play with the opacity, colour and bump to get the specific effect you are looking for (depending on the glass type you want to display)
There’s something wrong with transparency
Thanks for your help, i post a video gif in ten minutes
refractive index no working to
enscape version
](Imgur: The magic of the Internet)
The frosted glass effect is coupled to the roughness of the material: the higher the roughness, the stronger the glass blurs the background.
Refraction will only have a visible effect on curved surfaces.
Perhaps when ticked it could automatically set the roughness to (eg) 30%? (If it is = 0%)
That’s a good suggestion, we’ll think about that!
allright frosted work with roughness thanks, but this effect is better for proximity vision not for far. looks
it’s OK, the solution of Gadget work fine, i create a grey texture and i put amount of bump to 10.00 after the refractive index option take the effect to the top ! thanks
