Fstorm render
Sbrusse, how would you compare this to Redshift?
Some quick comparisons between Fstorm and Redshift.
The Fstorm is softer and the other one is much sharper. It looks like the AA filter is different. The right is warmer and the left is colder.
I think the only reason Fstorm look Softer is because it didn’t clean up enough, if you look where the sunlight is hitting the cabinets where it cleaned up easier you can see it’s just as sharp as Redshift. Fstorm does get odd lighting from it’s Fstorm sun/sky, do cold, a lot of blue bounce. This was to show quality and speed.
or maybe its that the glare option is on in fstorm which is enabled by default which is really nice if i may add but nice tests! i like F storm more though, seems more natural
Actually I turned Fstorm Glare option off to make the tests more the same.
Just to add, Redshift is also still using an older sky model not the new Hosek Sky model which it desperately needs.
Really would like to see explanation of those features, what we are missing here ?
This is great, thanks!
I can surely do measurements, both qualitative and quantitative, on residual noise.
I take it you mean using NO glossiness map?
Have you tried the same thing with the color2Bump on a GGX shader in V-Ray?
f.e.:​
Lele in regards to this is it possible in vray to get the anisotropic spread (probably using the wrong terminology) seen here on the circular metallic part in the attached image just via bump? I tried it a few times but never really manged to do this.
There’s an old evermotion tutorial about this : http://www.evermotion.org/tutorials/show/7875/anisotropic-shader-tutorial-using-vray-1-5-final-sp-1
Is this what you are after ?
Hi Oleg,
I am aware that you can achieve this with the anisotropy settings inside the vraymtl. But the render engines mentioned in this thread change the anisotropy based on the bump. So for example you use a bump map that mimics the circular brush pattern seen on metallic objects like the one I’ve shown, you get the “star pattern reflection” (don’t know how else to call it) for “free”. No additional anisotropy tweaking necessary.
Obviously this has its downsides too but I am just curious if you could actually mimic that behavior inside of vray.
The link is to a contact sheet with two diffuse, domelight renders at 0.03 NT for both fStorm and V-Ray.
Those are alternated by three film grain profiles (of those present in the default nuke grain node, the ones which show per-pixel sizes), desaturated.
The second row of each shows a 2X zoom into the bottom central area, to better gauge noise profiles.
I *can* tell a difference, and not a good one, in the fStorm render noise pattern, with the ugly horizontal streaking.
What i do not see is a particular similarity with film grain by either.
If you have a specific stock in mind, fine, but as you can tell, it’s not quite the valid argument, as there are a zillion stocks, with a zillion grain profiles, most of which with grains bigger than a pixel, and quite specific clumping…
https://drive.google.com/open?id=0B1P9eRh8EqXGc2ItMTVtcTdOdVk
Can i see the fStorm result and the shader build first?
Got it
Never thought about making it that way actually. Have you tried Color2Bump also ?
Here you go. I attached a screenshot of the shader + render result and the used bump map. It is a rough setup but I think it should be okay.
*edit* Oleg yup I tried that. :slight_smile:
Very nice, no you need the anisotropy rotation map.
Btw, how do you drive anisotropy amount and direction, with an exact normal map?
You should be able to do this with a bump map and no anisotropy without issues; you don’t need vraycolor2bump, just make sure the bitmap blur is 0.01
In the version i have, apparently i can’t set a shader’s closs to lower than 0.98, otherwise under environment lighting it goes pitch black, diffuse included.
ah!
I tried changing bump amount and filtering type.
Another reason why you’re boss. ^^
@Lele
To achieve a similar effect in vray I just use a spiral gradient ramp inside the anisotropy rotation map slot and reduce the refl. glossiness amount.
@Vlado
I can’t believe in all my attempts I never thought about reducing the bitmap blur to 0.01 and keep filtering on “Pyramadial”. The only difference is the bump strength needed for vray to give the same reflection pattern but yes it works.
(Sorry about the difference in brightness in both images)
