Full screen mode
hi. i want to know how Vantage fullscreen. i know there is hotkey Alt+Enter but I want to show vantage without any toolbars and menu.
Hi. Press Alt+Enter to fill up the screen and then press ` (the key above Tab) to enter “first person” mode - this hides the UI except for the status line at the bottom. You’d probably want to set your camera to Fill in case it wasn’t ( Chaos Vantage ).
Click ` (or ESC) and Alt+Enter again to return to normal mode.
thanks a lot. but I want to use this mode in the live link. I think person mode is not useful for live link.
I see. You can hide the side panels by double clicking on their tabs. That’s the most you can do in live link. The top and bottom toolbars will remain, but most of the window will be occupied by the viewport. It’s not much different from the V-Ray VFB when you set it up this way. Only the animation slider takes some area that the VFB doesn’t. It’s also useful to enable “always on top” from Edit->Preferences->UI when using Vantage as a VFB replacement.
Ah, you’re right. We also have the CTRL+` command which hides the UI without entering first person mode. I haven’t used it in a long time and forgot about it.
yes yes, that’s it. thank you :stuck_out_tongue:
Hi yones,
You can check and edit all available shortcut commands in Edit > Mouse and Key shortcuts
Alexander
I have a windows11 system with which keys does it workthe one there?
Tahnk you
Hi Mr Pock,
The shortcuts should be same regardless of the windows version. However for different keyboard layout (e.g. English US, Deutsch, etc.)you have to see( or set) the appropriate shortcut in the Edit > Mouse and Key shortcuts menu.
Alexander
Sorry do not understand the keys CTRL + `command
the CTRL is clear to me but the command key? And if I try all the available keys in connection with the CTRL key, I don’t get this result with the full screen mode?
I only have fullscreen but I still see the other command lines and not like in the picture where all the command lines are hidden?
I want the display for the Live Sync as on the JPG:
I also have a question how do I get to the command line?
Tahnk you!
The command (`) should be next to the 1 in the number row:
https://drive.google.com/uc?id=1\_jbvy5anp2A\_4vNud0\_9ckvxilvDlHwQ
The command is an additional exe which you run from CMD located in the installation folder of Vantage. You can check the docs here: Chaos Vantage
Alexander
Hello with me the command CTRL + `command does not work for hiding the command line?
what am I doing wrong?
Can you send a video of what is happening on your end?
Alexander
Once the normal display and once Fullscreen.
What is the keyboard layout that you are using (e.g. English (United States), Deutsch(Deutschland), etc. )?
Alexander
I think “Toggle Interface” should be in the View menu by default.
(If the menu is hidden, the menu can be made visible when the user points the mouse to the top of the window, etc., so that it can be restored even without hot keys.)
Also, Ctrl+` didn’t work well in my environment (Win11 Japanese with English 101/102 keys), so I had to assign a different hotkey.
I also posted it to the ideas portal (currently locked).
https://chaosvantage.ideas.aha.io/ideas/VANTAGE-I-221
