Fumefx 3.52 and vray 2.40.04 shadow receiving error
Hi, I have a scene where i have fume and some object which is casting shadow on fume, but even if i try all possible shadow types on light the fume itself is no reseiving the shadow from that object. In scanline renderer it works normaly with raytrace shadow type. I didnot tryed it in vray 3 so you can check it also. But do you thing it could be fixed?
Thanks a lot
I would try with V-Ray 3.0… we added some code specifically to handle V-Ray shadows and lights with FumeFX/Afterburn/ScatterVL. I think the only shadow type that didn’t work is the VRayShadowMap and we’ll fix that too.
thanks a lot Vlado
