fur looks different ADV/RT
hello there.
i get some quite different result here…
is there some used-look-switch i dont know?
Hmm can you give steps for reproducing ? Or maybe a scene ?
there is nothing special in this scene. just a circle with fur and a length-map for fur.
without length-map i have also different result.
I couldn’t reproduce it either.
We know that it is simple scene - but it would be much easier for us if you attach it.
Also please inform us about the exact versions of 3DSMax and Vray.
Thank you very much in advance.
i use MAX 2013, SP6; Vray 2.40.04
example.zip (33.2 KB)
Ahm I see the difference and will notify you in this thread about the progress of the investigation :slight_smile:
The problem is that you scaled your source object (the circle). This is a known issue - vrayfur+scaled geometry (and I hope it will be fixed soon). Please use non scaled objects for sources :slight_smile:
ha ha ha! and i started already to get mad to myself, cause i wasnt able to reproduce this again.
the matrix got me :smile:
