Fur obeying displacement of underlying geometry
The fur does not follow the displacement of the geometry which holds it. If the fur is long it might not be noticeable. But while using a thin coat of fur, the fur will be inside of the geometry or away from it. A method to offset the position of the fur with a map might be desirable.
Thanks for your atention
Christian
Thanks for the pointer; I added this as a feature request.
