Hi guys!
I have a sofa that has fur applied on a blanked. It runs normally when I open the object in a single window, but, when I merge this sofa in my project the fur loses its scale and gets to big.
If I select the option to not change the scale of the object when merge, the object is merged big. Then I realized that the problem is the scale of modeling (maybe it was made in mm and I’m working in cm).
How can I fix it whitout change the settings of the fur? (Its not working well, the sofa has at least 4 blanked like this)
