Furniture Design & rendered with studio lighting technique
Here is my newly designed furniture came out of my wild thoughts. Please feel free to comment. Expert users are specially requested to mentor some tips on improving quality.. :slight_smile: :slight_smile:
Re: Furniture Design & rendered with studio lighting technique
great design. render loos pretty realistic, though it’s kind of noisy… :stuck_out_tongue:
Thanks Omar… :slight_smile: Would you please like to suggest how to control noise, i do know a few ways but they don’t seem to work in certain situation.
Hello fantoosh, in order to control noise you have to tweak on your vray settings could you post you settings please to give an advice, and something very important its the lightning, what I do whan I apply a reflection to a material I add a high subdivision value something betwee 16 and 20 that helps to control noise on the material absorbing light. :slight_smile:
thanks for the suggestion Dave :). I tried something else too and it worked. I removed reflection property of background material, applied white GI for it at 5 multiplier, adjusted camera settings and finally adjusted Hsp. subdiv. and sample in irredience map. link to final adjusted vispot for less noise is https://docs.google.com/leaf?id=0B8lSWjo4BRjaMTZmMDFhMDItNDI5OC00YmY1LTljODgtNWU2MGVkNzgyNzRl&hl=en&authkey=CMbKy-wG
I will also try your suggestion… :slight_smile:
or also change the noise threshold to .005 :stuck_out_tongue:
here is a quick update with some fine tuning still needed… but so far i guess i’ve been able to control noise pretty much. I like your suggestion too Omar. It also worked really well, only at the expanse of render time… :wink: :wink:
IMO, it needs more light. maybe the noise came from lack or insufficient lighting
artu
nice work bro, but lightning is a little flat, maybe with a reflective floor and a more dramatic ilumination. keep up the hard work!
i don’t understand that about the flat illumination ehehe… no, just kiddin…
do you know what else you should do?.. increase the multiplier of those materials with a reflective layer…
8)
Fantastic renders!
