Furry pillows
After seeing this furry pillow on the forum https://forum.corona-renderer.com/ Italian design test
I thought I would give it a try.
Stock models, all shading lighting done by me. Fur on the pillow and blanket are Max hair and fur with Corona Hair shader.
Hope you like it.
Looks decent, some fixes are needed. Especialy on the shardess part.
This work would be more impressive if you would use your own models.
overal I really like the reflection on lamp and other metal objects.
Please take note that your sofa part is floating.
I agree it needs some work, however if you look at the Sofa as anything but the thumbnail, you will see the sofa has a thin metallic frame as well as legs suspending the sofa in the air about 100mm.
Thanks for the feedback guys.
I started this scene with only a pillow render and thought it would look nice in a small scene. I focused mainly on the hair and fur for practice. I didn’t notice the small gap between the sofa until the render was done.
What tips can you give me for the shading part?
