Why is it I can’t see the shadows in my renderings? I have Su shadows turned on and vray default lights turned off?
Re: Fustrated with Shadows!!!
I assume you are refering to the sun shadows. Having default lights turned off is going to prevent the SU sun and the Shadows to be rendered, so try enabling default lights and see if that works for you. Also make sure that you have shadows enabled in Global Switches.
It would have helped if I remember to switch my lighting from hdri to sky.
That will do it to ;D… sometimes the biggest headaches are from the smallest oversights…we’ve all had em
