futuristic superbike
Hey guys, I’m working on a futuristic superbike concept. Going for a nice design, don’t ask me how it works ;).
Any constructive ideas are very welcome!
[Edit: attached new thumb here] [the B&W pics are the first ones]
I know how it works - motor spins the wheels and bike rides forward :] But even if that’s just concept, headlight should illuminate road more than a front wheel ;]
hey romullus, thanks for the explanation :). and good point you got there. also, many parts are still too lowpoly imo. trying to model some parts with fusion 360, which seems very powerful for hard surface.
Looks promising. I am looking forward to seeing it in a better matched environment, with better lighting and materials.
yep, workin on it, thanks Maru.
Update:
  • I followed your good advises & added some different enviro(still rough) & hdri lighting
  • materials + model details further refined
  • headlights are located on the sides on the frontwheel
I think I won’t change a lot on the bike now. Enviro needs some details…
It’s getting better, but such tyre protector would make riding not only very unpleasant experience, but it also would be quite dangerous i suppose.
do you mean the back extension of the seat?
No, i mean tyre itself. Protector is designed in such way, that at lower speeds, ride would be uncomfortably bumpy and at higher speeds, especially when cornering, tyre would loose too much traction and that could lead to loss of control. But i’m no expert in such things by any means, it’s just my personal opinion.
ok, that’s probably correct, no expert here either. I should try some proper tyre modeling with some kind of insets. thanks for the efforts
I have been working on this a bit. What do you guys think? Is this ready for the gallery?
its so sick! nice work man
Hi, thank you. yes I did some post. I was also experimenting with less contrast looks, but not on all images…you can also check newer renders here. https://forum.corona-renderer.com/index.php/topic,11159.0.html
