Gallery
Gallery made based on some reference.
The photos of the pictures are mine
i like the light much!! Try to denoise the pictures a bit!!
Very nice clean render.
I like the lighting allot. Did you use a hdri?
I can see a bit of repetition in the floor texture on the first render.
Thank you very much!
@krimson
I just used the Sky Corona and Corona sun for lighting.
I tried to vary the textures the maximum I could, but this went unnoticed.
Would you like to provide us with some more information? Rendertime, modes, setup etc.?
Hello mp5gosu,
I did render on resolution of 1337 x 1559 why was the same resolution as the reference image.
Regarding the render time I do not remember, but I left for 400 passes each image in HDCache mode.
Lighting I used the Corona Sun + Corona Sky
The setup I used was:
Exposure (EV): 2.0
Highlight compression: 10.0
White balance: 7500.0
Contrast: 1.5
Love the lighting indeed. Did you use the default coronaSky? What sun and sky values did you use to get the nice soft shadows?
Please share. Thanks!!
Hello rambambulli,
I used the default values of Corona sky and the sun. I decided to disable the sun because I did not want to put in the glass translucency, this would increase the time of surrender.
