My Vray version seems to be unsuitable for this task even after conversion and fiew hand tweeks.
Did any of you go around making materials like that? How do you aproach it?
I’d say you’re pretty much on the right track with that test. You might just want to tweak the maps in the reflection and glossiness slots to produce stronger reflective and glossy changes (slap a colour correction modifier on the same map and play with contrast / output e.t.c).
Post up your current mat settings so we can see what’s going on. Perhaps you could try putting some maps into the anisotropy / rotation slot and see if that produces the desired effect?
It might also be worth putting the mat on an different objects in a scene with real geometry around it as the environment is so crucial to the look of the reflective material.
Ok so I’ve imported your material into one of my WIP scenes, you can check it out against my current galvanized mat. Let me know if you want my settings?
No worries, I’m no expert and my mat isn’t finalised either I guess it depends what you’re going for, I was trying to get a darker more industrial galvanised look, where the reflections aren’t quite so prominent:
