iv just been playing with the new build and I noticed the gamma correction in the colour mapping rollout, is there any documentation on this, does it work the same way as the gamma in maxwell?
gamma-correction is the same as linear, only it corrects the rgb channel in VFB. It has been put there to correct for your monitor gamma.
example: if your monitor gamma is 2.2 (standard) then correct it by using .4545 (1/2.2) in bright multiplier. dark multiplier stays 1.
But first take the time to read all about it here
