I´m having diferent gamma values on buckets thru distributed rendering + backurner.
I think is a gamma issue, because you see the same texture only lighter.
I can see this error on the total lighting pass too. the other passes seems ok.
thank you
I had the same problem. Turned out I had forgotten to update Vray on the faulty computer who made the lighter buckets.
thank you.. I’m going to triple checked that.
Yea had the same thing the other day… one copy of vray just didn’t install correctly ![]()
