Gamma slider for roughness map
Status: declined
It is really hard to create realistic look with only one slider for roughness map. Gamma slider would help. Much better would be three sliders (classic levels sliders: black, white, gamma) or curves settings.
Submitted on AHA Ideas by Peter Stano (ENSCAPE-I-1468).
ok then keep only one slider, but it should be set in the middle. Moving it to the right should increase brightness and moving it to the left should decrease brightness. I use enscape because it is fast, any workarounds in other image image editors are slowing down the material setting process. It is basically back and forth (changing the brightness, levels, gamma, saving image, loading image) checking how it looks in enscape. Therefore i think it should be built in enscape to have immediate visual control over the material settings process.
Submitted on AHA Ideas by Peter Stano.
AHA Ideas status: Declined.
Set during AHA Ideas to Discourse migration.
