I have upgraded to the latest vray 5 from initial 5 release. Normally I could save the results from vfb to jpg/tga with all correction applied and it looked the same. Now it seems that no gamma is applied. Where I can find this magic tick to make it work again as it was before?
That would be the opposite what @urbanite wants.The default in 3ds max is set via MAXScript this way:
fileoutgamma=2.2
First make sure Gamma is enabled in 3ds max Preferences under Gamma and LUT.
TGA/JPG output will match V-Ray VFB if Display Correction is set to Gamma (matches 3ds max) or sRGB (slight difference in this case) there.
You can also do a test render using Scanline renderer to test 3ds max Gamma options are setup correctly.
Thanks for reply. I do have the correct setu, gamma is enabled and set up to 2.2. Apparently there is some glitch in the scene I am working on. The new one behaves as expected.
