Hi guys must be over a year since posting anything so here goes…
C&c welcome…probably need to add more furniture etc. internally
Max 10,V-Ray and photochop
Cheers
Tdarcy
Very, very nicely done fella!
yeah i rather like these…
though im not 100% sure the background images match the 3d as it feels somewhat wonky, where as the 3d is perfectly aligned… perhaps its the slope of the land giving the illusion.
Thanks guys for the comments. I must admit the background photos were not taken by me which was a bit annoying which meant I got only vague info on camera position and levels etc. so had to make do .
Cheers
TD
very nice renderings, I’d turn the interior lights off (1st one).
how much of the plants are photo and 3d. only the background trees?
great work!!
only critic is that the materials are looking a bit flat.
Maybe try a bit more bump map and a bit more reflection to help liven them up
all the best
good job. My coment would be that the intergration of the cg needs a bit more attention:
the cg has too little contrast between the sun and the shadow. Also the saturation and the fact that the blue shadows on the live house are much deeper in color then the cg ones. If you can correct that, it would be a very solid intergration.
very nice work!
The base of the building could do with dirtying up and darkening, especially around the orange door on the first image. Just stands out quite a lot from the photo as it’s pretty bright.
can i see photo with original building ?
