Gaussian Splatting CPU rendering updating objects
I have an scene with many Gaussian Splats. It seems that during animation rendering, the objects need to be updated every frame. But all the objects are static. Would it be possible to calculate this at once?
It appears to update on every frame. Not sure if this is equivalent to “loading” it again, though. I’ll ask the devs and get back to you.
That would be great! Thank you. I use a lot of Gaussian Splats now. Sometimes it takes 10-15 seconds to load every frame. Hopefully this can be calculated ones.
How are you using them , out of interest, is it survey info or models you have mad and reusing them to save memory?
Thank you for the question. I have made several Gaussian Splats that I copy and combine to one big scene where a camera flies through. The scene I have now uses 100 splats. It will take time to load them. If this would be calculated ones, the render speed will be much faster.
Can you give any more detail about the project. So have you modelled the Buildings for example and Converted them to Splats and the reffed them in to a base scene?
I still have not found a way to sue them in Daily work that is not time consuming.
Thank you
Phil
I am specialised in creating cosmic nebulae environments using billions of particles. Rendering these billions of particles will take a long time. So a year ago I thought lets try gaussian splatting to create nebula structures. After a lot of trial and error I got to the right quality. Then I placed these new nebula forms in 3d max and render them using Vray. I am almost done with my first journey and it renders pretty fast. The scene has now 100 splats, each contains 4 million splats. The render time with motion blur is now around 1 minute per frame on a threadripper pro 3975WX cpu. That is still pretty long but I am now pushing the scale. For smaller projects the speed would be much faster.
That sounds like an interesting way to do nebulae. Are there images you can share of this?
Just a thought, do you know of Krakatoa? Maybe it’s worth a look for that type of thing, as it seems an ideal fit if the splats don’t work out quick enough.
Hello, I am creating nebulae for the past 8 years. You can find my work here: https://www.behance.net/salmonickproductions. I have done VFX work for Star Trek, The Orville and many other cosmic projects. You were spot on! I developed my work using Houdini but for the past 7 years I am using Krakatoa because of the rendering speed. Still the rendering speed is pretty long. Therefore I was experimenting with Gaussian Splats and the result is really great.
Hehe yeah I can imagine that it’s not quick when doing so many large scenes such as on your webpage. It was extremely slow when I used it years ago, so did hope it might have increased in speed, but
maybe splats is going to be better, so I’ll be really interested in your results.
You have some awesome looking work there, gratz!
There’s a lot to look at so I’ll have a good look through them all in the morning :slight_smile:
Confirmed by vlado - Gaussian Splats are currently loaded for each frame even if they are static. I’ve logged an improvement request (internal tracker ID: VMAX-15204) on your behalf.
This is amazing! With these improvements the rendering speed will be much faster! Thank you so much for developing this further. :slight_smile:
I have a question…or rather a guess; for the Krakatoa method, are you running fluid sims and using the meshing of those to birth the Krakatoa particles, deriving their colour from the uvs/ texture of the fluid mesh, or is it something different?
I don’t expect you to reveal all your secrets of course, it’s just how I would imagine doing it, based on old knowledge of Krakatoa (makes me want to try this out for sure) :slight_smile:
Thank you for your comment. I have developed my work using Houdini. There I used smoke simulations to create the basis of my work. For a while I used that as a starting point. Later I went to 3D Max to render with Krakatoa. Then I started using FumeFX again to generate the smoke simulations. I also used multiple levels of noise fields to add more detail to the particle flow. You can also use Stoke to transfer the smoke to particles. I dont transfer colour from the simulations. I use many lights with multiple passes to later combine them in post. This way you have more freedom to tweak later.
Thanks for the breakdown - pretty much as I thought then, which is good to know. I’ve been using Embergen recently, as it’s so capable and extremely cheap to rent, so once my current job is done in a few days I will definitely see what I can
do with this approach. I’ll post anything of quality that I manage to create :slight_smile:
I agree it’s probably far better to use lights for these types of setups. As I recall, years ago I was doing stuff with cars, and so my tests were using the model’s textures to drive the particle colours. It did work really well but at that time was just so slow as to make it impossible to
use in any practical way.
I am pretty familiar with the process of creating nebulae using FumeFX + Krakatoa. But I am curious of the process using splats for such purpose because splats cannot be lit by lights, so I cannot use light sources inside nebulae to create volumetric effect. Could you tell how you add light effect to splats in this case, please? I love your nebulae renders from the link you posted. It is only a bit weird that you do not make bright stars visible, which actually create the light on nebulas.
Yeah, it would be amazing if at some point we can relight Gaussian Splats. I saw that the Unreal plugin Volinga supports the relight option. At this moment I am also exploring that. But with the project I am working on right now, I ran out of VRAM. The plan was to place multiple GS inside a scene. Unfortunately 32 gig was a problem with the amount I had in mind. Therefore I am now rendering CPU based. Btw, I added a relighting option at the ideas list. Hopefully they will implement it at some point. For now I create many nebula structures with different light setups and then create a puzzle in 3D Max to combine them to the scene I have in mind.
Thank you for explanation!
Linking threads because, after further testing, GaussianSplats seem to already be loaded once for static splats. Info in the other topic.
