General Comments for Discussion
I believe some of the competitors for Enscape is Lumion-Twinmotion and Octane.
The greatest advantage of Enscape is the Livesync with the VR (we have Vive) platform and Archicad. Lumion has only panorama as 3d and Twinmotion is not livesynced.
Also the rendering seems more realistic with Enscape because it looks like it uses raytracing while Lumion and Twinmotion looks fake and a bit cartoonish.
Octane has a far more advanced rendering core and texture control but needs a lot of power, it is not livesynced with Archicad, so you have to update at each change the whole model which takes time,
and it is not VR at this stage (only panorama pictures).
So, Enscape seems at this point seems the best in matters of Architectural workflow. It suits perfectly with the design stages, it is fast, simple and with a good quality of rendering and the most important thing is that it does not create laging with the creation process. You design, you see right away .This is perfect for a designer.
As an archicad user, the most important thing is the texture editing (bump,displacement, normal etc), the light controls with the ability to have different light textures or ies data, and the improvement of rendering. So far with just a TITAN X (Pascal) and about 2.500.000 polygons (a lot of 3d object imported) things work not so fast. There seems to be a certain lagging.
I have another TITAN X that would have been used if Enscape was Multi GPU.
I am really waiting for an upgrade.
Keep up the good work.
@ArchitectsVR IES lights should work out of the box. If not, you can you send us the model with the missing light and we will take a look.
Hey @ArchitectsVR thank you for the positive feedback! Multi-GPU support is a feature request already filed on our agenda which just received a further upvote! :slight_smile:
