Hello, I saw on escapes blog post that with the latest version, there is now a visual settings dialogue box and a general settings dialogue box. However, I can not seem to find the general settings dialogue box while using archiCAD. Furthermore, I don’t have the material editor showing up for me. Am I missing something? I have attached a photo of all the options I am given when I select enscape while in ArchiCAD. Thank you.
window > palettes > Enscape
@Crow_T.Robot - If Tikos’ answer doesn’t help you out, that looks like your Enscape installation is corrupt and incorrect.
I would recommend, in the first instance, uninstalling Enscape completely, reboot the machine and re-run the Enscape installer to install Enscape again.
If you still have issues seeing the General Settings and Material Editor options, then you should send us some logfiles via the Enscape Feedback function, making sure to include a link to this thread in the Feedback window, as well as your email address.
Thank you Tikos. That worked perfectly. I should have known to look there. ![]()
@Crow_T.Robot - there is also a new Knowledgebase article regarding enabling Enscape in ArchiCAD.
Great! I will make sure to read through it. It looks like its filled with great information.![]()
