Geometry disappearing in larger projects
Not sure if this is due to my hardware or just a bug in the system.
Revit- projects + Enscape. Whenever I have a larger project with hundreds of trees, a larger environmental project, including a detailed interior project both in same project, a small edit may make some geometry disappear. For example, I might edit a tap in a toilet, and all the closets of the toilet disappear in the next live-sync-update. Sometimes moving a door or making any other minor change will make the closet reappear, but that is random and rare. Sometimes switching a 3D imported from Revit helps, but sometimes not - and always closing and reopening Enscape helps, but that makes a serious flaw in my workflow.
This does not occur in bigger projects.
Is this a matter of my hardware, or matter of the software?
I9900K
32gb RAM
RTX 2070S 8GBVRAM
Only SSD
1440p screen, if that has anything to do here
Thank you and keep up the good work.
I’m sorry to hear about that @Sheik_1 ! In the first instance, it would be great if you could send us a feedback report as described here. If possible you can also gladly share the project with us - if that is possible, please let me know and I’ll provide you with an upload link. If not, then the report will have to do in order to troubleshoot this. Thank you very much in advance!
