I am working on a building model using REVIT 2018.3.2. Rendering 3 linked building in a model. Wall surface on one side of the building was populated with diagonal bumps (see image attached).
There’s also light leaks at junction of roof and wall (see image below)
In my model, there’s not gap in the roof. Wall height is set to the under side of the roof (did not use top attached).
Also I find the ORBIT mode does not work consistently.
Has any one come across these issue? If so, do you have solution that you can share?
Thanks in advance for your comments.
Best Regards,
PaulM
Hi @PaulM_1 and welcome to our forums!
Those shadowing issues (the diagonal lines on the first screenshot are also false shadows) are unfortunately a known issue of our initial Enscape 2.4 release. We’ve in the meantime improved sun shadow calculation to reduce artifacts like that. Could you please to download the latest version of Enscape from our download page and see if the issue persists? There’s a link the Enscape About window (“Visit download area”) that will lead you there.
You might also get improvements of the visual quality if you increase the field of view to higher values if that is possible for you. Looking at your screenshots you’re using an almost orthographic perspective.
Hope that helps!
