I’m trying to use VRAY to make a render with SketchUp. This is my first time with VRAY.
The result is good but I get some problem with terrain model.
As you can see there are some lines on terrain:
Model
Render
How can I remove it?
Model
Render
Are you using V-Ray Displacement? Turn on the V-Ray displacement parameter called ‘keep continuity’ to get the render to continue the displaced surface between non-coplanar surfaces.
Yes I use displacement but the “keep continuity” is active:
V-Ray material:
Render:
Any ideas?
Try to soften/smooth the edges of the terrain.
How?
I just try to click with right button of mouse on terrain, select option to soften/smooth, change value.
In this way on SketchUp I don’t see geomtry lines any more but on render I see my of these (not all).
