Hi
is there a way of improving the appearance of the geometry, it Look smooth in Revit but looks really poor on Enscape.
Btw using RVT 2017
@jwal485 , we would gladly check this behavior out - could you briefly send me the project file which includes this object? Maybe this object is also really small?
Attached, it is quite small!
Neko Kenzo.zip (987 KB)
This behavior is actually normal when it comes to very small objects due to performance optimizations. Is there any particular reason why you’re using an object of this size?
Can you simply increase the size, as this would also resolve this.
@azur.design , even these objects are kind of small, so this behavior is normal. You can of course also send the project over just so we can make sure that everything is behaving as accordingly. ![]()
