Get Vray Light Dome texture
Hi, does anyone know the proper max script command to get the texture path ?
if its a regular bitmap, and the dome light is selected, you can use:
$.texmap.filename
otherwise if its a vrayhdri/vraybitmap and the dome is selected you can use:
$.texmap.HDRIMapName
Thank You ! This worked for my needs
