Is there a way to get the installed VRay version through a python script? I don’t see an ENV Variable or a Registry Key.
I found you could run vray.exe -version and then regex the stdout but is there a better approach?
With maxscript you could use:
vrayversion()
or you could use:
getFileVersion(“$max/plugins/vrender2016.dlr”)
(assuming you’re checking in 2016)
They format the output slightly different
For the newest V-Ray versions (3.6.x) you can parse the first line from vraylog.txt file, located in %TEMP% in Windows, the version is stated in that line.
Thanks Ivan. How long does that %TEMP%\vraylog.txt file last though? And is it created without any renders being done? I’m trying to keep tabs on rendernode version numbers (so maxscript is out too). I have a solution using the exe -version flag. But it’s a little slow.
The vrayVersion() MaxScript command is the best way to get the exact version. It is available in V-Ray 3.6 as well.
The log is created when you start 3dsMax with V-Ray installed and is re-created on every 3dsMax start. It’ll stay in the folder unless it’s deleted on purpose.
