Hey guys!
Is there any way to get the OCIO file Path in the VFB?
I’m looking for a way to know if there is any path written here.
Thanks!
Not sure what you mean. If you’ve loaded an OCIO config in the designated slot it will appear there; this includes the case where the configuration is loaded via an environment variable. Nothing is loaded in the attached screencap.
I want to get the OCIO config path, easy. ![]()
Ofc in the attached screencap that would return “” because it’s empty. It was just to show you what I’m trying to get.
Ah. This should do it:
vfbcontrol #ociofile
Great! it works perfectly thanks ![]()
