Hello guys
I have a problem with distribuit render, when I send the DRrender on 10 machine i have a ghosting problem on the image,I tried to shut down individual machines one at a time but the problem remains,when get the data from the slaves there is the problem, have you never had a problem like this?
Looks lika a known issue (which cannot be easily fixed - if ever) with perspective view and DR rendering (as it is implemented now)
- Are you rendering a perspective view? If so, create a camera to render
- What version are you using? In newer Corona versions there should be a warning if you render a perspective view with DR.
Good Luck
tnx for reply
use corona 1.3 and render from camera, i don’t understand where is the problem
More things I can think of: Do you have camera motion blur enabled an the camera is (slightly) moving (doesn´t look like this exaclty but with extreme settings it may)? Or do you use any camera correction modifier?
Good Luck
don’t use motion blur or dof for this render, and with or without camera correct the problem is the same…
Are you using standart camera or vray camera?
There might be some instalation missing on single node.
Try using debug - retive exr to detect the node wich is causing the artifacts.
BTW. This might be not only camera. It might be also some third party gemetry plugin wich is missing on one of the pc’s.
use only standard camera, no missing plugin, this scene had been already rendered previously without problems with the same pc and the same configuration…for two days i try everything, i use debug for check the .exr but the problem is random sometimes on pc1 sometimes on pc2,pc3,pc4
Then you should write a ticket and upload simplified scene to the bugtracker.
OMG you should have posted earlier. Sounds like a problem with the scene or a bug now. And yes, I would open a ticket here:
https://coronarenderer.freshdesk.com/support/tickets/new
I think maru will gladly take a look.
Good Luck
ok thanks a lot guys I will upload the file
I swapped out the PhysCam for a CoronaCam and this fixed the problem
