Ghosting artifacts in animation when using Vantage Anim. Export from Corona
I’m getting ghosting/streaking on objects when rendering animations with Vantage Anim. Export from Corona, but the same scene renders clean using Vantage Live Link.
Interestingly, the ghosting only happens when the camera follows a custom spline path. With a simple linear camera movement, there are no artifacts.
I’m using corona 13.1 and vantage 3.0.3
Has anyone encountered this? Any workaround?
Thanks!
We will need at least a screen recording do understand what you are referring to.
The scene with reproduction steps will be even better. By the way, have you tried with latest Corona 14?
Thanks for the quick reply!
I haven’t tried Corona 14 yet – I’m still on 13.1 because some of my projects are still in progress.
I’ve done a test with 4 frames, and you can see blur streaks on the objects that look like motion blur, but I don’t have any motion blur settings enabled at all.
I’m using a camera animated with 3ds Max’s Walkthrough Assistant tool (following a spline path). Interestingly, when I use a simple keyframe animation on a straight line, this issue doesn’t occur.
Could you please send us this vrscene (and the assets next to it) at https://support.chaos.com/hc/en-us/requests/new ?
Thank you in advance!
