I have an interior scene, with some character animation and GI: wich tipe of irr. map do I have to use? single frame, multiframe increment., ecc…
Most likely you want to use Single frame high a fairly mid-high setting..
Probably start with one of the ‘Animation’ gi presets and customize it as you need to conserve speeds..
If you can, its generally faster to render seperately and composite together in post, but it really depends on the scene.
