Here two small tests which make me slightly panic (hint: I need that differences list ). All settings are identical in both versions!
Softshadows: they look worse and take 50% more rendertime in 1.46 (with same subdivs on the lights - I thought they would need less)
GI: notice the detail under the handle in the 1.09 version, and the rendertime… I thought the new build needed less hsph subdivs, but they need more actually in this example. Rendertime doubled! The difference may be small but GI detail is what it’s all about and if rendertime doubles in a simple skylight scene…
Vray 1.46 can indeed get away with lower Hsph subdivs for the GI, but you need to lower the interp samples also! It interpolates much better than 1.09 (even with the same interpolation type). When you leave the interp samples at 20 (as I did in my tests), you simply blur out the good GI solution completely.
I used interp=8 and hsph=25 in this image! Notice how the detail is now better than in the 1.09 image, but at the walls it is worse. But that’s the compromise of interpolation vs quality which you will always have with blurry methods.
You can see that the 1.46 version took more irradiance samples than 1.09, so it’s natural that it’s slower.
Actually…I can’t really see that 1.46 took more samples…looks about the same…the bigest difference is that the sample dots are much larger…thus appearing more dense. Shouldn’t the vray log window show how many samples were taken?
Trixian,
You can see that the new build took more samples than 1.09 in the ceiling.
Over large flat areas, it is obvious that there are more sample taken.
