GI "life" multiplier or similar
Is it possible to add a multiplier which can change the way light spreads in GI precalculations. So it let the light ray to travel and scatter longer and not to die so early.
I suppose the result will be exaggerated shadow occlusion when still using weak lights. It will be usefull lighting low light dim scenes.
Excuse my ignorance if such multiplier or solution already exist.
You’re excused if you promise to give a thorough read here :
:wink:
Lele
Lele,
If you mean Secondary bounces multiplier - it is fixed to max1.0 and on other hand it would just multiply the overall strength of the sec. bounces and will not change the lenght of traced path.
If you mean QMC GI “secondary bounces” → “It controls the number of light bounces that will be computed”, but it controls where to stop getting in count bounces and not how far it will bounce. For examle let set bounces to 8 but light falloff algorithm is phisically accurate and most of the samples will not live till 8, and on the 3-4 bounce would have no visual effect .
To be more accurate I want light falloff multiplier which would allow the light rays to bounce deeper in the scene and to produce noticable effect. If possible of course.
I tried to find such thing which can change the life of the ray but I couldn’t.
If there is something I’ve did not notice please show the right place where to read.
I’ll be happy to see color bleeding control in GI too.
You could always set the Generate GI multiplier per object to something higher than 1. It would give you more light on the inside but may produce some weird results as there’s potential for the surfaces to radiate more light than is actually in the scene, leading to some weird feedback where the light levels grow exponentially. I think this is why the multiplier is locked at 1 now (it used to go to 11 :wink: ).
dlparisi,
don’t want more light, but to scatter existing light deeper. Also deeper is not so important as every next bounce to have more energy.
other suggestions?
Sorry to bring it up, but the solution really is LWF. You argued against this in Nikki’s thread but this is exactly what it acheives. There is no “multiplier” but using proper LWF allows for less light to travel deeper into interiors.
EDIT: I reread this post and thought I should rephrase… LWF allows using less light which will actually appear travel deeper into the interior.
ZIING!!!
lol
<gulp>
:slight_smile:
:lol:
very happy to see you again.
another solution is using the lightcache.
that’s 100 bounces for you.
Oh, and possibly a slight 2.2 gamma applied :lol:
Lele
:lol:
*wipes tear from eye*
eheheh :lol:
:lol:
Realise that I did write a lot of trash in the poll. Sorry for that. It’s offen happen to me to get fired in totaly wrong causes. That’s me :sweat_smile:
I was wrong on following:
-light scatter more - its only appear to scatter more.
-LWF results are not photorealistic - OK, in dim (interior, cloudy) scenes it produce better results than working in Gamma 1.0. It’s looks closer to real life lighting because of the occludded shadows look. But not when there is harsh light presented(sunny exteriors, sunspot in the interior), then working with Gamma 1.0 is easier to setup. Thats why I decide to ask for another possible solution, (if I’m not totally wrong again), a real light “equilizer”.
And to cut nonconstructive debates let stick on argueing on “the wish” and not on LWF. It’s apparently that my “wish” is not presented among “buttons”.
LWF is great solution. But why to not develope vray more.
best regards
appreciate your attention on my posts :smile:
You might wish to check out my script pack on scriptspot (Lele’s VRay Tools): it contains a matrix exposimeter that does “equalize” light.
As well as an old-ish video tutorial i prepared a while back on the tips and tricks section of the forum, which deals with outdoor lighting under sun and sky.
What it does is to lower the diffuse coefficient of surfaces (speeding up GI tracing by 2.5X), and to bump it back up with the (in)famous 2.2 gamma.
For exteriors, it works pretty consistently and with eye-pleasing (read: photographically close) results.
In interiors, it still works, but one needs to be a bit more careful, and might need a slightly higher multiplier for diffuse values.
Throughout the mammoth thread you’ll find various samples and tests that speak for themselves.
VRay IS developed to a really really nice toolset.
It’s my firm belief that it should not constrain the user too much, but leave freedom to explore.
And that it does marvelously.
Do dig a bit deeper in the forum and you’ll see.
Lele
i double that!
Lele,
really appreciate your efforts related to LWF. Very useful tutorials for better understanding how vray acts.
“VRay IS developed to a really really nice toolset” but WILL develope further.
ene.xis
Please provide search keywords or links for deeper digging.
:lol:
u got a pretty nice button up on the navigation bar “search”…just give it a go! :wink:
what ur asking here as been adressed tons of times…so a little up-to-date reading is a must.
GI bounces, multiplier and gamma - that’s all you’re looking for.
The number of bounces which is only really relevant to secondary bounces set to qmc or photon mapping. It will affect how many times the light can bounce before cutting off - i’d say most people would recommend using light cache for secondary gi though where you just get infinite bounces.
Gi Multiplier will affect how much energy the light loses each bounce and will determine how quickly it fades off - Vray has the max of this set to 1 - there is no current way to make GI bounce more light than it has received in keeping with the realistic approach of vray.
Gamma - it’ll affect how bright the midtones of your image are and is probably the biggest part of lwf. As Lele mentioned there’s tonnes of stuff out there for it.
“Gi Multiplier will affect how much energy the light loses each bounce and will determine how quickly it fades off” - I didn’t realise that. Thanks
This is from Vray Help.
“…this determines the effect of secondary diffuse bounces on the scene illumination. Values close to 1.0 may tend to wash out the scene, while values around 0.0 may produce a dark image. Note that the default value of 1.0 produces physically accurate results. While other values are possible, they are not physically plausible.”
This is the reason I was confused that it is overall sec bounce light multiplier.
Apparently I’m totally wrong again :sweat_smile:
