muoto
June 10, 2012, 9:43am
1
i got this very simple scene, a base of a studio set up with a ground+wall and a thin and thick glass object
when i render this, i have this strange ugly GI in the glass…
simple omni, vray dome light, irr map and lightcache
where is the problem ???
Thanks!
ps: attached jpg and max scene
vray trans gi.zip (28 KB)
muoto
June 10, 2012, 9:58am
2
OK, found out that the simple background plane with a simple glossy reflection is messing up the tranparency/gi problem
edit : simple reflection on that plane, even without glossy is messing up the transparency
edit 2 : even without glossy, i have strange GI in the thick glass box…
edit 3 : well… it seems whats messing up, is the vray dome light. When i turn it off, transparency is fine…
is there a fix?
thanks
tick the retrace threshold (and set to 1.0) in the light cache options maybe?
muoto
June 10, 2012, 10:46am
4
light cache is turned off… just irr map
so brute force 2nd bounce?
muoto
June 10, 2012, 11:45am
6
No, nothing as 2nd bounce (just to see where the prob is coming from)
i tried with vraylight planes, even with 256 subdivs, and i also have strange gi effects in the refraction
muoto
June 10, 2012, 11:51am
7
well…i think it’s more irrmap related in a way…
i changed the sample lookup to overlapping, instead of density, and result is much much cleaner !
no idea then i’m afraid, I’m not much of an expert with irradiance maps!
(adding a light cache as 2nd bounce with default settings but telling it to use light cache for glossy rays (not ticking retrace threshold) seems to give a decent result)
You would need to enable Affect reflection option of the dome light on order to get a correct result.
muoto
June 11, 2012, 9:09am
11
hmm..yeah but when doing that, i loose my custom panoramic env map i use for glass materials
What exactly are you trying to achieve?
Where do you set the env. map: domelight, environment or environment override slots?
muoto
June 11, 2012, 7:14pm
13
i normaly place a 360° pano in the glass for reflections, and a kind of studio setup for lights and background.
so i just need clean transparency, GI, and light reflection in the glass
Hello there.
This problem can be fixed if you choose " Treat Glossy Rays as GI = Always" from “Options” rollout of your backplate material.
