glass cabinet corners
hi all i’m working on an exhibition space with some glass cabinets, which have seamless corners, I have modelled the glass as one object and also as four seperate sides with 45degree angles joining them (if you know what I mean) but I seem to be getting these strange light beams in the corners anyone know ho I can avoid these?
Thanks Dom
Hey. Does the glass have depth or just planes? Also, show us your glass material please. :wink:
I’m wondering if you have a white exit color set in your refractions. That could cause that. Also you might want to up the max depth up on the reflection and refraction. 10 or 15 might be good.
V Miller
yep what they said.
1. make sure the glass has thickness..not just a plane
2. show us your glass material
3. try increasing the max depth of your glass material
I would model the glass as on big piece. You would get better refraction that way.
thanks for the reply guys - this one is one whole object (spline then outlined and extruded up); as per this image
and the material is;
nothing fancy just made it see through and reflective really, could it be because the diffuse colour is white, although when I set the diffuse to black it comes out like tinted glass
i’ve also modelled the glass as four seperate objects like this;
but still get the same results
thanks Dom
Yes, that is because of the diffuse color.
Recommendations:
(*) Make the “cage” of simple boxes, with slight chamfers on the edges, so each box represents each side - the way it would be done in real life.
(*) Use the fog color and multiplier for your material setup.
(*) Set the diffuse color a bit darker than your fog one (20-30% darker)
nikki Candelero
thanks Nikki , I’ll give them ago 8)
