hi,
i have to do a conference room with a backlight ceiling, i wonder what kind of shader to use to get this effect from light coming from behind the ceiling.
also i’m looking for fabricant reference of glass and light ceiling
thanks for help
hi,
thanks for help
I’ve used the vray blend material to do this before.
Bottom layer would be a vray light material with an image in it for the vague shapes/distribution behind the glass (light spread/colours) and the layer on top was the glass with masks in reflection/refraction to add the seams.
cubiclegangster: That sounds like a good method. Do you have an example that you can post? Thanks.
I cant remember what job I used it on unfortunatly. There were 2, one a lobby and a school but it’s going to take me a while to dig for.
I’ll browse whenever I do a test render today and post it up if I find it.
yes this sounds good, i’m going to do some tests with your methods.
would be nice to see the result you got
thanks
You can also try the VRay2SidedMtl. This works good for me. Refer to spot3d for more info.
