Glass/reflections/alpha channel ?
Hope somebody - who is a bit more in to rendering than me - can explain a little thing for me :
I am used to do renderings of buildings (exterior and interior !). My question is as follows…
When rendering interiors with glass (with reflection/refraction) I used to place a “stage” on the outside of my building - with a bitmap of the sorrounding area to give it a more realistic touch. But now - when using Vray - I use the invoronment multiplier a lot and this seems to make my “outdoor” bitmap VERY bright. Is there a way to render the scene with the glass and its reflections WITHOUT the outdoor bitmap - and then place the picture in the scene later in photoshop ? I normally render as tiff and then use the alpha channel in photoshop - BUT - then I don´t get my reflections in the glass with me !!!
Reading the above I know that it is VERY badly explained :sweat_smile: - but I hope somebody understands what I´m trying to say :wink:
In advance - thanks for your time and be good !
- rolnik
Play with the Generate GI & Receive GI parameters in the VRAY Properties for your background object. That will allow you to get the brightness of your background down to the desired level.
:lol: Thanx for the tip !
But where do I set VRAY properties for a specific object ?
I´ll try and figure it out my self - but if you happen to drop by again and have time then please tell me !
Have a good day !
I have the VRay Properties configured into my Right Click menu.
You can assign it either to a shortcut, tool bar or quad menu from the Customize User Interface panel. Group=Main UI and Category=VRay. This was introduced in VRay 1.09.03j.
Alternatively, if you place your background material into a VRayMtlWrapper, you can set the same properties there.
Thanx for the help :smile: !!!
