Glass superposition Problem
So I’ve encountered something twice with thise project. When I take a shot from an object in front of another object which both are at a different transparency setting, they will nul themselves. I also found that if you create the same superposition but its foliage over glass, the foliage inverts…(the living room on the plant in the middle of the scene, there is a glass bowl behind it)
I have found that it’s the third layer (and beyond) of glass where you will see the glass on glass effect. (The full bottles are obviously not transparent)
(And it’s a pain that glass simply does not cast shadows.)
reflections are the number 1 bug I believe rn
Both will be fixed with our next upcoming hotfix release Enscape 2.5.2. Stay tuned for that. :wink:
