Glass texture issue
These is a same building rendering, first image was rendered by 2.02, and second image was rendered by 1.96.
Why the old verion glass is better? Can you guys fix this texture issue?
The milky look of your glass windows are not related to reflection quality, it comes from a high material opacity. For glass, you usually always want to use an opacity that is as low as possible. The specular reflection component is unaffected by a materials opacity.
But why is big diffent between 1.96 and 2.02?
Because we improved Enscape and fixed several bugs im past 8 months :slight_smile:
Have a look: https://enscape3d.com/knowledgebase/sketchup/
Use the glass keyword and a low opacity. Then it will be fine. You will get a dedicated material editor for the next version.
Can’t wait for the editor and new materials! :slight_smile:
