This may have been covered, but I can’t find it .
Interior set up, rendered and the glass in the window is 5mm thick, and I can’t get it to reflect a slight amount for the perfect look.
Can anybody help me with this please?
Image attached
Glass reflects brighter parts (interior) if the behind is darker for most part. So either you use such override for visibility which preserves darker alpha map and some reflection on glass, or you overlay reflection pass of light (using matID select) on top of you background in Photoshop as well.
Corona 1.4
Max 2017.
I have seen the guide, but still no reflection from the surface of the glass on the inside really, with out compositing in PS afterwards.
